Compare models
Which Brokk is best for your work? Here you can select different demolition robot models and compare their specifications and features. If you compare several models, scroll sideways to see them all.
- Width min.
- Height min.
- Weight
- Recommended attachment weight
- Horizontal reach (incl. breaker)
- Vertical reach (incl. breaker)
- Transport speed, max.
- Power
- Pump flow, 50Hz
- 780 mm; 30.7 in
- 1160 mm; 45.7 in
- 990 kg; 2183 lbs
- 180 kg; 397 lbs
- 3700 mm; 146 in
- 4300 mm; 169 in
- 2.5 km/h; 1.6 mph
- 19.5 kW
- 54 l/min; 14.3 US gal/min
- 780 mm; 30.7 in
- 1160 mm; 45.7 in
- 990 kg; 2183 lbs
- 180 kg; 397 lbs
- 3700 mm; 146 in
- 4300 mm; 169 in
- 2.5 km/h; 1.6 mph
- 20.2 kW
- 56 l/min; 14.8 US gal/min
- 1600 mm; 63 in
- 1677 mm; 66 in
- 5200 kg; 11,464 lbs
- 700 kg; 1543 lbs
- 7000 mm; 276 in
- 7300 mm; 287 in
- 1.8 km/h; 1.1 mph
- 41 kW
- 115 l/min; 30 US gal/min
- 1200 mm; 47.2 in
- 1530 mm; 60.2 in
- 3650 kg; 8047 lbs
- 500 kg; 1102 lbs
- 6100 mm; 240 in
- 6500 mm; 256 in
- 2.7 km/h; 1.7 mph
- 37 kW
- 100 l/min; 26 US gal/min
- 780 mm; 30.7 in
- 1351 mm; 53.2 in
- 2100 kg; 4630 lbs
- 350 kg; 772 lbs
- 5100 mm; 201 in
- 5450 mm; 215 in
- 2.1 km/h; 1.3 mph
- 27.5 kW
- 85 l/min; 22.5 US gal/min
- 780 mm; 30.7 in
- 1254 mm; 49.4 in
- 1600 kg; 3527 lbs
- 270 kg; 595 lbs
- 4400 mm; 173 in
- 4800 mm; 189 in
- 2.1 km/h; 1.3 mph
- 24 kW
- 69 l/min; 18 US gal/min
- 597 mm; 23.5 in
- 880 mm; 34.6 in
- 560 kg; 1235 lbs
- 105 kg; 231 lbs
- 2700 mm; 106 in
- 3200 mm; 126 in
- 2.7 km/h; 1.7 mph
- ABB
- 27 l/min; 7 US gal/min
- 2150 mm; 84.6 in
- 2545 mm; 100.2 in
- 11,400 kg; 25,133 lbs
- 1500 kg; 3307 lbs
- 8500 mm; 335 in
- 9100 mm; 358 in
- 2.8 km/h; 1.7 mph
- 55.5 D, 71 E
- 148 l/min; 39 US gal/min
- 2150 mm; 86.5 in
- 2545 mm; 100,8 in
- 11,600 kg; 25,574 lbs
- 600 kg; 1323 lbs
- 9500 mm; 374 in
- 10,000 mm; 394 in
- 2.8 km/h; 1.7 mph
- 55.5 D, 71 E
- 1600 mm; 63 in
- 1680 mm; 66.1 in
- 5500 kg; 12,125 lbs
- 700 kg; 1543 lbs
- 6700 mm; 264 in
- 7300 mm; 280 in
- 2.5 km/h; 1.6 mph
- 55 D
- 130 l/min; 34 US gal/min
